Applying glue to edge when joining top http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=26954 |
Author: | lactose [ Mon Apr 12, 2010 12:25 pm ] |
Post subject: | Applying glue to edge when joining top |
Are there any tricks to apply a little glue as needed to the edge of a spruce top that I will be joining ? Last time the excess glue left some little spots. |
Author: | SteveCourtright [ Mon Apr 12, 2010 12:49 pm ] |
Post subject: | Re: Applying glue to edge when joining top |
lactose wrote: Are there any tricks to apply a little glue as needed to the edge of a spruce top that I will be joining ? Last time the excess glue left some little spots. The way I read this, the implication is that your excess glue left spots on the wood last time you joined a top. I think the solution is to join your plates before you reduce the thickness to final dimensions. Whether you remove excess glue immediately or after it sets up a bit is not critical, if, after you have joined the plates, then you finish plane or sand to final thickness. The act of finish thicknessing by sanding and/or planing will remove any excess glue. |
